Stretch objects only by X or Y direction
Is there any way in Auto Cad to stretch or move geometry or grip points to other reference point without any distortion. It is a sort of snap setting which is available in 3ds max called " Enable Axis Constraints". It helps you to move objects only orthogonality . You can specify any reference point knowing that your object will move only by x or y direction. As you see in the image, if I move the grip point and I want it to be aligned to the height with the adjacent object, it wont end up being distorted. This feature would be very handy with stretch command, If anyone knows how to customize that in CAD it will be a big help.
Thank you.
