I've made dynamic block of a window.
With a visibility parameter I can choose between 3 different views (front and sections..)
With several linear parameters I can change the width, height and other layout variables.
However changes are limited to just one block reference of that block.
Is there a way (VBA?) to have all references of that block in the drawing share the same dynamic block properties library, so all references are updated if you change one.
Using a regular block of course solves this problem, but at the cost of losing the ease of the dynamic block editability.
Any help or tip welcome!
