Search Paths - Support File Search Path & Printer Support File Path Changes
lunarleif
lunarleif
Good afteernoon,
When installing AutoCAD Architecture 2026, the Search Path locations for the Options --> Files various paths have changed, aren't present, and so on. For 2026 some of the folders aren't even created, DWG to PDF .pc3 is missing, and several other things. Have tried reinstalling and for some that fixes .pc3 but the other parts remain missing and or changed. Any effective solutions or reasoning for this? Thank you very much for your time.
pendean
Community Legend
Community Legend
@lunarleif Not seeing anything like that in my ACA2026 installation, but you can and probably should just go ahead and add what you need manually too, those buttons are here to do that (or try a repair reinstall or more)
If you feel the program is missing content or should do more on it's own... Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
