Save 2019 file as 2010 version
I am using Autocad architecture 2019 but work uses Autocad architecture 2010. I tried the object enabler, but the only one I found was not English.  Is there an English version. I need to be able to save files so they can be edited in 2010 version.
pendean
Community Legend
Community Legend
There is no ability to save AEC content (walls/doors/ceilings etc.) from ACA2019 to ACA2010: you should never have opened and used ACA2019 for your work files.
You have very few options, all painful https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Backwa...
Thank you, I will check out your link. I actually haven't opened the work files yet. Worst case scenario, I can explode all the AEC content as the end file would only be used for the archives. I was hoping there was an easier way. Thanks again!
pendean
Community Legend
Community Legend
I'm glad you checked ahead of time 🙂
