"DIMADD" command to default to a custom layer instead of "G-Anno-Dims"
Mjkushy
Observer Observer
Mjkushy
Observer
Observer
I use "DIMADD" all the time but these strings always end up on "G-Anno-Dims" even though the dimension style is set to a custom "Dimension" layer. I use a lot of layer isolations and I would like to know if there's a way to change this default setting so that these AEC strings end up on "Dimension" layer without selecting these strings and manually changing the layer to "Dimension".
David_W_Koch
Welcome to the community!
Edit the Layer Key Style you use and change the Layer associated with the DIMLINE layer key.  You may also want to make the same change to the DIMMAN layer key, since it is also mapped to G-Anno-Dims in the out-of-the-box AEC Title Case - NCS 256 Color Layer Key Style, and possibly other out-of-the-box styles.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
