I am trying to create a new Dimension Tick (Arrowhead) to replace one I created back in the early 1990s and have been using ever since. Please refer to the included image of my dimension styles below.
There are three different dimension styles with the only difference between them being the Arrowhead. The first dimension is my original one. The second dimension is my original using the Architectural Tick supplied with AutoCad. These both appear as desired. The third dimension uses a new arrowhead I created similar to the Architectural Tick supplied with AutoCad but it does not display as desired and as you can see in the image, the dimension line stops short of the extension lines.
Below each dimension is an exploded version of each with the right arrowhead moved to the side. For my original dimension style you can see that the dimension line does not extend all the way to the extension line and my arrowhead is an architectural tick with a short portion of dimension line to fill the gap. I do not remember the exact reason for this but it was required at the time, or so I thought, something about needing to fit in a square one unit by one unit. In the second dimension using the Architectural Tick supplied with AutoCad you can see that the dimension line does extend all the way to the extension line and the arrowhead is just a tick. This tick is a block named "_ArchTick" and when exploded, it is just a polyline with a thickness. The third exploded dimension uses my new custom arrowhead, a polyline with thickness, similar to "_ArchTick" supplied with AutoCad, and as you can see in the image, the dimension line does not extend all the way to the extension lines.
My question is, how do I get the dimension line to be continuous between extension lines using a custom arrowhead? In the Dimension Style Manager I have tried every combination of settings and nothing works. As a test, I also used a renamed, unmodified "_ArchTick" supplied with AutoCad and the dimension line was not continuous between extension lines. This made me think, is there something about the name of the arrowhead that makes AutoCad construct dimensions in a different way?
Lee
