LISP in ACA 2011
LISP in ACA 2011
LISP in ACA 2011
I noticed something strange in ACA 2011, I run a lisp routine for all my shortcuts etc... and I noticed in the new version my command for explode ((defun C:EX() (command "explode")) does not allow me to select mutliple objects. When I type in EX the command line reads Select Object: when I type in the command "explode" the command line reads Select Objects: (With an 'S') and I can window and select multiple options. Anyone have any ideas to what is casuing this? Its the only command so far that I noticed the issue.
See the initcommandversion function in the LISP help.
> /((defun C:EX() (command "explode"))/ does not allow me to select
> Select Object*s*: (With an 'S') and I can window and select multiple
Works like a charm now, thank you for your help.
You're welcome 🙂
