Hello guys!
I am using AutoCAD Architecture and for a long time I have been searching for a solution for integrated door markers. My desire is a simple door tag which contains the measurements of the AEC door and dynamically changes as the door alters. The tag should be contained within the door block itself.
A possible solution would be if I could create from scratch a custom door block that works in the same principle as AEC objects?
Till now I have tried (with zero success):
Any suggestions?
I created a Schedule Tag for my doors years ago based off the Standard Doors Sizes on my doors. Is this what you are asking for?
This works for a door tag to display the way you want.
You'll need to update the multi-view block you are using to tag your doors with the following:
Edit your existing display block used in the tag or assign a new one with the following:
1.) An attribute with DOOROBJECTS:HEIGHT, set to justify MIDDLE RIGHT, with its origin point at 0,0
2.) An attribute with DOOROBJECTS:WIDTH, set to justify MIDDLE LEFT, with its origin point at 0,0
Make sure to ATTSYNC your display block after the change.
