How to retrieving global and local component names from AEC styles
tbrammer
Advisor Advisor
Message 1 of 1
tbrammer
I'm developing an ARX using OMF on plain AutoCAD (not Architecture).
To query the component names of door- and window-styles I use the OMF API:
  AecDbDictRecord::getMaterialComponents(
          AcGeIntArray& ids,
          AecRmCStringArray& compNames,
          AcDbObjectIdArray& materialIds
On German and English AutoCAD versions getMaterialComponents() returns different compNames for the same style in the same DWG:
    compNames (doors)       compNames (windows)
ids German    English       German         English
1   Rahmen    Frame         Rahmen         Frame
2   Türstock  ?             Fensterflügel  ?
3   Füllung   Panel         Glas           Glass
4   Glas      Glass         Sprossen       ?
5   Sprossen  ?             -              -
So obviously I get “localized UI-names” in compNames. Are there “local” and “global” names stored in the DWG?
How can I retrieve the “global” names? I have to make sure that I get the same names on every language version of AutoCAD.
Note: My test DWG also contains a wall style with additional components. For this style getMaterialComponents() returns the same (German) component names in both AutoCAD language versions. But here I get totally different values for ids:
ids     German/English
101         Außen
103         Innen
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Replies (0)
