Hello everyone, We are currently building an AutoCAD Architecture connector, Is there a method within the AutoCAD Architecture .NET API to retrieve the project APJ file of current active project? I'm require access to the project APJ file for my application. Any insights or sample code on how to accomplish this would be very helpful.
Hello everyone, We are currently building an AutoCAD Architecture connector and need to access the tabs within the Project Navigator programmatically using the .NET API. Any guidance or code examples would be greatly appreciated
All the support is provided at the file system level and there is no support for interacting with the Project Browser and Project Navigator UI directly from the API.
You will need to reference AecProjectBaseMgd.dll.
Autodesk.Aec.Project namespace.
Sample project AecProjectBaseSampleMgd in
Sample project AecProjectBaseSampleMgd demonstrates the use of the Project Management system.
The sample implements “ProjectSample” command.
[ls/cd/open/pwd/check/mode/upgrade/downgrade] Options:
