custom library in ribbon panel
h.zarouali
Observer Observer
h.zarouali
Observer
Observer
Hello everyone,
is there a way to ad custom library in auto cad. But it has to be fixed on the ribbon panel.
I have seen it before, but i can't figure out how it has been done
Does anyone knows how i can do it?
In the picture below you can see where I would like to put the multiple libraries with custom blocks in.
pendean
Community Legend
Community Legend
The RIBBON customization is we defined, but it's not going to look like what you sketched out.
Are you just wanting to create a row of button to click on to insert your custom content? Then move the QAT from above to below the Ribbon
Then create your desired -INSERT command macros or LISP as "new commands" in CUI's section here
Then drag-and-drop them to the QAT like this
There should be enough space for 100-ish button if that is all you need.
Any reason you're not interested in simpler solutions like Toolpalettes or the classic ADCENTER command?
