aecLayerKeyOverride using VBA
Message 1 of 8
How can I utilise the aecLayerKeyOverride command in Visual Basic?, I wish to create a building using the elevation command for the floor height & aecLayerKeyOverride for the layer names, the elevation bit is easy enough but how do I use VBA to do the "aecLayerKeyOverride" - "level" - "02" for example, normally done within the dialog box.
Replies (7)
Message 2 of 8
Ed,
Use the follwing code and reference the necessary files.
Dim LayerKeyStyle As AecLayerKeyStyle
Set doc = AecArchBaseApplication.ActiveDocument
doc.Init ThisDrawing
Set LayerKeyStyle =
doc.LayerKeyStyles.Item(doc.Preferences.LayerStandard)
LayerKeyStyle.OverrideSettings("level").value = "2"
| Rob Starz
| Stardsign cad solutions
| AEC Designer / Consultant / Developer
| iC - AEC Information Center
| www.stardsign.com/aecic.html
| "can we make it any easier?!"
Message 3 of 8
Rob,
Many thanks - I'll give that a go. are there any reference books available relating to using VBA with ADT3?
Eddy
Message 4 of 8
Rob
Tried that & am getting an error message from the last line
saying that "method 'Item' of object 'AecLayerOverrideSetting' failed".
The value of the level should be "02" and not "2" as I said, but using "02" makes no difference.
Eddy
Message 5 of 8
Rob/Eddy,
There are still some issues with setting Layer Overrides if the override
has not been inserted previously in the drawing (3.0), and if the layer
functions have not initialized yet (3.0 and 3.3). I think Peter or Mark
probably has more information about the conditions than I do.
-Danny Polkinhorn
Perkin & Will
Atlanta
EddyRichardson wrote:
> Rob
> Eddy
Message 6 of 8
I didn't include all the code for initializing. I have had no problems with
code like this on old dwgs or new. I just include and error trap to detect
if the override is not present and then import it.
| Rob Starz
Message 7 of 8
That was exactly what I was trying to point out! It seems like he's
tripping over the initialization problem. It shouldn't matter if it's
"2" or "02" or "Starz" as long as it fits the layer standard.
-Danny
> | Rob Starz
Message 8 of 8
Were you really!...I don't get it...come again..
After conversing with Eddy via email...He sent me a file with the Override
to be set but the "level" was "Level" and the level callout was padded with
a zero so it should read 01, 02.
| Rob Starz
