aec dimension superscript only 5 or 0?
maurot.ferrarese
maurot.ferrarese
I just need exactly what is written in the title, how do I display the superscript of the aec dimensioning either 5 or 0, and not the numbers in betwenn. For example, if I measure between 2 walls and the real distance is 1,58³ meters, how do I do to automatically display 1,53 meters instead. If the case is 1,536 then it should display 1,54. I know I could manually edit this number but I have this case several times and would be time consuming. Any idea or suggestions? Thanks in advance
_Steven_
Hi @maurot.ferrarese,
Hello
As I'm not fluent in English, I'm not sure I understood what you wanted, but I'll try to answer with the help of an online translator.
First of all, if you don't want an exponent in your dimensions
go to the AA options and then to the AEC Dimension tab.
Uncheck Use Superscript mm. This will display the dimensions with 3 decimals.
If you wish to have only 2 decimals, you need to modify the dimension style used in the AEC dimension style you're using.
Select an AEC dimension, then right-click. In the context menu, go to Edit AEC Dimension Style...
Check the current Overide Style.
If this is already checked, click on Edit Display Properties...
Next, click on Edit (1).
In the parameters for the dimension style used by the AEC dimension style, go to the Primary Units tab (1), then set the precision to 2 decimal places (2) and confirm.
Is this what you wanted?
Steven
Ce post vous a été utile ? N'hésitez pas à aimer ce post.
Ce post a-t-il répondu à votre question ? Cliquez sur le bouton APPROUVER LA SOLUTION en dessous de la réponse.
« L’homme de bien n’exige pas de l’autre qu’il soit parfait, il l’aide à accomplir ce qu’il a en lui de meilleur. »
Lao Tseu
