XList Missing from Command List
Message 1 of 8
I've had a hand-full of issues getting started with ACA 2015, but I've been able to fix most by reinstalling.  I can't, however, find the X-list command.  Is it working for anyone?
I didn't realize how much I used it until now.
Replies (7)
Message 2 of 8
dbroad
works here as xlist
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
Thanks for your reply,
I miss typed xlist previously.  In ACA 2015, I get cuixlist when I type xlist.  xlist doesn't  even show up in the Command list (see attached).
Message 4 of 8
dbroad
Autodesk has completely messed up the command line with autocomplete and autocorrect.  If you turn autocomplete off, you can't even get the stretch command by entering S.  If the command exists, a sure way to get it is to enter .xlist.  Notice the period before the command.
Message 5 of 8
David_W_Koch
XLIST works for me in ACA 2015.  As Doug mentioned, AutoComplete may be changing the command on you - look carefully at the command line.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 6 of 8
I've tried every combination of commands beginning X or .X and scrolled through the drop-up list - XList is dead to my machine.  When (if) I have the time, I will try reloading libraries, etc. to see if that helps.  Where would the default download for the command files be?  Are they CUIX files?
Thank you all for your input
Jaimal
Message 7 of 8
Jaimal,
I have the exact same issue as you do. XLIST is not even a command anymore on my machine. It's been this way for me since day 1 at my new company.
In addition, I do not have the BURST command.
Other computers at the company have these commands, but for some reason, I do not.
If you have found a resolution, I would appreciate hearing it.
--Jerad
Message 8 of 8
dbroad
XLIST and BURST are express tools commands.  Unless you load the expresstools (either during installation or with the EXPRESSTOOLS command) you will not see those commands.
