my xreference file is not up to date with current drawing. it doesnot show up as an attached file
when I go to reattach the file it says that it is a block already in drawing
is there a way to remove the block status and reinsert an xref to be so that it can be clipped
Solved by David_W_Koch. Go to Solution.
Solved by dbroad. Go to Solution.
If you're just using AutoCAD techniques, then use the blocktoxref Express Tools command. Otherwise, if you want to use the project navigator delete and purge the block out of the drawing. Then use PN to add the construct to the view or the view to the sheet.
It sounds as though your externally referenced DWG file was bound into the file, converting it to an internal Block Reference.
You can:
Do the first option if you need to maintain the location and clip extents of the bound version so that it can be used as a guide when positioning and clipping after externally referencing the file. Once the external reference is set up the way you want, you can delete the bound block references and then purge the block definition.
@kgm2535 wrote:
Hi Dave
renaming the block and purging the block worked
what did you mean about deleting all block references
I used layer not involved in the xref to locate the floor plans when repositioning the xref
thanks
kevin
Either renaming or purging should have worked. If you were able to purge the block definition, then there must not have been any instances of the block definition in the file to be deleted. I was assuming that the originally externally referenced file was bound and that there was still at least one instance in the file.
For what it is worth: you can also use XCLIP on Block References (internally defined). It is not restricted to externally referenced files.
