X/Y Coordinate Green and Red lines
could anybody tell me how to deactivate this green and red line from my screen?
Every time that I try to type the length  and angle of the lines, those are intercept with the green or red line.
(Here is an screen shot )
David_W_Koch
Not sure how having the X- and Y-axis colored red and green interfers with coordinate entry, but if you do not want them to be colored:
1.  Type OPTIONS at the command line, and press the ENTER key.  (Or open the Options dialog in any other way you like.)
2.  Select the Display tab.
3.  In the Windows Elements area in the upper left, select the Colors button.
4.  With the Context set to 2D model space and the Interface Element set to Grid axis lines, clear the checkmark from the Tint for X, Y, Z toggle, just below the Color drop-down menu on the right side.
5.  Select the Apply & Close button to dismiss the Drawing Window Colors dialog.
6.  Select the OK button to dismiss the Options dialog.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Thanks,it works.
