- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I open in read only then in command line I type WHOHAS hit enter ask me what file name.
I attached two pictures you see.
There is question after it say, Would you like to open the file read-only?
Other picture say, User: Unknown
We keep all our drawings in our network drive for our company.
I resend the attach file for you to like at.
Thanks, Richard Pineda
Specialist 2 Architectural,
Facilities Architects
Are you trying to figure out why the file is opening read only?
Were the screen captures you posted the correct ones? One shows what appears to be a plan view, with no interface context. The other shows what appears to be the same plan view, in Revit, which is not the software this forum covers. Your question is about an AutoCAD command, WHOHAS, which is not seen in either image.
If this is a Revit question, this thread can be moved to the appropriate forum. If it is an AutoCAD question, then it will help if you can explain your problem in more detail, and include the correct supporting images.
