Workflow Assistance - Custom Paneling System
Im a bit rusty to AutoCAD as 2006 was the last time i used it, and also a noob to Architecture. I'm trying to create a Panel system that will need to be repeated frequently, and Im looking for an efficient way to draft this . I need to add firring to a wall then add panels that need to be uniquely identified to generate a cut-list as well as assembly elevations. Is there a way to tile a "wall style" with a block or create a "curtain wall" to do this, or do i need a custom lisp to accomplish this?
leothebuilder
You can use a dynamic block to create your system wall with the panels.
By creating each panel as a block you can add a material list via attributes and extract this information into an autocad table of excel file.
