Window grid patterns
tevansERD
tevansERD
Do you have to create separate window styles based on size if the grid rows and columns change based on the size of the window? Example, a 3050 window might have 6/6 grid pattern but a 4060 might have 8/8, or is there a way to make the number grow and shrink based on the window size?
Oilymo
Sounds like a job for curtain walls.  You can set fixed cell dimensions or fixed number of cells.
Ben
Victoria.Studley
Hi @tevansERD,
Were you able to try out the curtain wall feature to achieve your goal, as @Oilymo recommended?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
ntellery
Not with the Window object. It's a set number.  You would need a separate style for each variation.
With DoorWindowAssembly objects you can set parameters so 'a new pane per 600 distance' etc so you have more flexibility but they do work quite differently and take a bit more to get a handle on.
CurtainWalls are almost the same thing as DWA but are designed to be stand alone walls.  DWA's cut openings in walls whereas CWA don't.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
