Why is file open/save done thru command line only? How to toggle it back?
What I'm used to is that when I initiate an Open or Save As command, a Windows-Explorer-like window comes up which allows me to select folders and files and change file names.  Somehow I accidentally toggled something so that file open/save done only happens through the command.  How to toggle it back?
leothebuilder
Set FILEDIA variable to 1
That worked. 1,000 thanks.
tm_eichler
New Member
New Member
Very important. Open first a random 'last opened' drawing. Than type 'in the drawing' : FILEDIA set to 1
