Walls hatchs & Cut planes
Message 1 of 1
Plesae help all i want is for my adt walls to show a hatch that i specifiy in display objects and the openings.
It seems that because of the cut plane option i will sometimes get only half the wall hatched becasue it maybe a glabel wall and the eaves is lower than the cut plane.
If i change the cut plane and make it lower then it goes below the opening and doent show the opening. Surely regardless of wall size and cut, there is a setting that will allow you to alowys see openings and always hatch from end to end.
Anty help would be greatly aprpeciated
thanks
Replies (0)
