AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wall Styles not showing after crash.
9 REPLIES 9
Message 1 of 10
aratcliffeSR2FJ
1474 Views, 9 Replies
aratcliffeSR2FJ
My Architecture wall styles aren't showing on plan. This only happened after I crashed. Does anyone know why this is happening?
9 REPLIES 9
Message 2 of 10
Katsuaki.T
Hi @aratcliffeSR2FJ,
Welcome to Autodesk community!
The settings of AutoCAD Architecture may possibly be damaged due to the crash. Please reset the settings of AutoCAD Architecture to try to solve the issue.
If this is a drawing specific issue, the drawing may be corrupted. Please repair the drawing by running AUDIT command.
Katsuaki Takamizawa
Technical Support Specialist
Katsuaki Takamizawa
Message 3 of 10
aratcliffeSR2FJ
Hi, thanks for your reply. It is a drawing specific issue but unfortunately the Audit tool didn't work.
The problem may be due to the fact that my wall styles were attached to my hsbCAD walls. (HsbCAD is basically a plugin designed to apply timber elements to Autodesk tools).
What is strange is that my walls still have the wall style information shown in the properties tab it just doesn't show them in plan view. For example, the "Browse" tab (before I crashed) showed a graphical representation of the wall style but that doesn't show anything now. When I use the Browse tab to try to reassign the wall styles it doesn't change anything.
Message 4 of 10
Katsuaki.T
Hi @aratcliffeSR2FJ ,
Thank you for providing the additional information.
Could the style be corrupted? Is it possible to copy the same style from another drawing using Style Manger and replace with the one having the issue with the one copied?
Katsuaki Takamizawa
Katsuaki Takamizawa
Message 5 of 10
aratcliffeSR2FJ
I just tried copying a different wall style from another job. Unfortunately it still doesn't show.
Message 6 of 10
aratcliffeSR2FJ
Also, my wall styles can be seen in Isometric views, just not on Plan.
Message 7 of 10
Katsuaki.T
Did you check Display Manager for Plan view to see if any setting is missing?
Could you share the drawing? If you could not share the entire drawing, could you WBLOCK the wall with the style to a new drawing to share with us if it can reproduce the issue?
Katsuaki Takamizawa
Katsuaki Takamizawa
Message 8 of 10
aratcliffeSR2FJ
I've attached the drawing. I crashed again this morning and when I go from one level to the next on some occasions my wall disappears. For example, if I go to my first floor walls I cannot see them. However when I go to my layout, I can see them are still in the drawings.
I definitely think there is something up with my display functions.
Message 9 of 10
Katsuaki.T
I am sorry for the delay in responding. Thank you very much for sharing your drawing.
I am not sure which walls are having the issue. Would you please tell us which wall style of walls are having the issue? Are these proxy objects supposed to be displayed?
Katsuaki Takamizawa
Katsuaki Takamizawa
Message 10 of 10
aratcliffeSR2FJ
Hi, Katsuaki Takamizawa. It seems like the issue has been resolved, all my walls are displaying correctly, I'm not sure how though. Good end result though.
