Wall problem
Wall problem
cddrafting
Wall problem
cddrafting
I have just commenced having a problem with my walls. I have been using this CAD file for some time now and I now have a visual wall problem that I seem to not be able to solve.
When I draw a wall and insert an opening from FFl I now have these extra lines appearing on the plan and on the print that I cannot remove. They are part of the wall.
How do I hgo bacl to having this additional blue line hidden ?
Chris
David_W_Koch
You have Justification Display turned on.  The blue lines are the Edge component of the Graph Display Representation for Walls.  If you are using the out-of-the-box display settings, these lines should be mapped to a non-plotting layer.  To turn off Justification Display, select one of your Walls (any one will do).  On the Wall contextual ribbon, on the Cleanup panel, the Justification Display tool should have a higlight.  Select it to turn off the highlight and the Justification Display.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Soyoung.H
As David's explained, it is because Justification line.
Please check this Help article.
http://docs.autodesk.com/ARCHDESK/2014/ENU/files/GUID-33F8B759-ECFE-4359-B186-C95C98B30D36.htm
Soyoung.H
