- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have searched and found some complaints about endcaps but not many solutions. Neither could I find a solution to my problem.
I am making some firm standard wall styles and I typically use a pline to make an endcap style. Mostly this is needed for masonry returns at windows and doors. No matter the wall style the typical masonry component just needs to return 7 1/2". Seems simple enough. And it seems that the same endcap would work for all. However, every time I assign the endcap to a different wall, it is always off a bit. Then if I edit in place it wants to rename it. If I try to overwrite the original then it doesn't work for the original wall. I have ended up with multiple endcap styles with different names that are exactly the same. Very frustrating. I can usually 'work around' ACA's little quirkiness but this is just mind boggling. What could be so hard about returning one component 7 1/2"??
Surely I am missing some simple step or technique for assigning an existing endcap to a new wall style.
Any suggestions are as usual greatly appreciated.
Keith D. Rodebush
RA
