How do you remove the yellow boxes which appear attached to wall ends in plan view?
They are probably dimension markers indicating there is a dimension that can't display. Why are you using 1:1 annotation scale? You are looking at a building after all, not a door knob.
Theres no dimensions on this drawing. It's a construct in Architecture rather than a drawing. It looks like a set out point or something attached to the actual wall itself. I've looked in the wall style display but cant see anything to turn them off.
Did you change the annotation scale? Post the drawing if you continue having issues.
Yeah, changed scale but I think its to do with the wall style itself. I've attached the drawing below.
Cheers
There are no particular problems with the interior drawing, although, it is certainly a strange bird. Here are some non-standard items:
Look for issues in your xreffed drawings. We can't see those since they weren't posted.
Thanks for that. It's actually a timber frame wall, from a timber frame manufacturing program which is a bolt on to architecture. Thats why the plasterboard is drawn seperate to the wall itself.
Its the actual set out point of the wall, or something, that seems to be displayed. I just want to get rid of these if possible.
You probably should work with your timber frame program writers to avoid the need for multiple parallel walls. It's much easier to maintain a single wall than 3 or 4 parallel walls.
