Wall command outcome keeps changing
cddrafting
cddrafting
When I use the wall command to draw a wall it use to draw the wall with the inner and outer wall shown with the cavity. As I draw the wall I can see the inner and outer walls but once the wall command is completed it only shows the outter most wall lines.
Any one know what is happening her and how to fix.
It is driving me crazy.
In the attachement I am half way through drawing the se ond wall. Whn I finish I will end up with only the two outter lines. The attachment 2 is the continuation of the first attachment
Chris
David_W_Koch
Are you drawing a Wall of the same style as the one to the left side, running from bottom to top of screen, which does show the inner components (and component hatches)?  If so, both Walls should display the same way, unless you have an object-level override on the Wall to the left, to get the components to display.  My first suggestion is to check the height of the newly drawn Walls.  If they are shorter than the cut plane height, the inner components will not display.
If the Wall is intersecting the cut plane, some additional information will be required.  Have you modified the settings associated with the High Detail Display Configuration, specifically the Plan High Detail Display Representation Set and the Plan High Detail Display Representation for Walls?  Can you attach a sample drawing file that exhibits the problem in a reply to this thread?  (You need not post your entire drawing, just a few sample Walls that show the problem.  If you can include a Wall that works as expected also, that would be a plus.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
cddrafting
David
I am drawng a wall of the same style. What I did was to select the wall and 'add selected' to draw the new wall.
You commented on the cut plan and wall heigts. I did check those but what seems to be happening is everytime I select a new wall the wall height seems to default to 600 even when I 'add selected' and this wall is 2400 high.Thank you for the solution.
On another matter can you assist.
With why I am now getting these blue wall lines with all my walls. It even prints which now makes the drawings incorrect.
File attached
Chris
Soyoung.H
Hello-
Thank you for attaching the drawing file. It helped a lot to sort out the issues 🙂
First of all, the blue line is indicated as a floor line.
Second, in AutoCAD, if you open the drawing file which was created in AutoCAD Architecture, you may get the message.
You can install Object enabler for AutoCAD or you can save the drawing file by using Export to AutoCAD.
Object enablers for AutoCAD 2015
And for the Wall command, I tried to reproduce the problem, but I couldn't.
Please check the Screencast file below.
https://screencast.autodesk.com/Main/Details/62cd829b-7236-442b-81e7-e76eae882481
Soyoung.H
