View Cube be gone
View Cube be gone
View Cube be gone
We are just now getting into ACA2011, having skipped 2010. The workspaces tool bar is gone, which we used only to ensure that the autocad workspace re-loaded just like it was when last open. We do not use more than one workspace.
I'm not interested in setting up a new workspace, I only want the changes I make to the default architectural to be saved so that when I re-open ACA, it is identical to the last time. The View Cube seems resistant to this, even after going into the CUI and clicking the Save button while the main architectural workspace is selected, this after turning off the View Cube.
Is there a secret to prevent the annoying View Cube from loading every time?
KathyMoffa
Options/3D Modeling/Uncheck View cube.
You're a genius...thank you!
