AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
VBA macroses are not evaluated
3 REPLIES 3
kokospb
505 Views, 3 Replies
kokospb
Hi!
I have a problem using schedule tables and tags, containing VBA macroses. Instead of evaluated result I see the whole macros text in schedules. Reinstalling VBA for AutoCAD Architecture, VBA libraries or AutoCAD Architecture itself doesn't change anything. Last time the problem was solved by reinstalling windows 10 and programs. Any better idea?
Best regards,
Konstantin Naumenko,
Senior Architect,
RUUKKI Corporation.
Hi!
Best regards,
Senior Architect,
RUUKKI Corporation.
3 REPLIES 3
David_W_Koch
in reply to: kokospb
David_W_Koch
Are you talking about VBScript formula properties in a Property Set Definition?  Those do not require installation of the Microsoft Visual Basic for Applications Module (VBA) for Autocad.
Typically, displaying the entire formula in a Schedule Table or Schedule Tag indicates that there is an error when the formula property was evaluated.  The values of any properties referenced in the formula replace the property references so you can try to debug the formula by seeing the data that generated the error condition.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David Koch
Blog | LinkedIn
kokospb
in reply to: David_W_Koch
kokospb
Thank you for the answer, David! Yes I'm talking about VBScript formulas. But it's not about errors in them. ALL formula properties are just not evaluated. Even the simplest ones and those that worked fine before. I think it's somehow system related, because older ADT versions performs the same. Software only reinstallation is not helpful, but windows reinstallation does.
Best regards,
Senior Architect,
RUUKKI Corporation.
Best regards,
Senior Architect,
RUUKKI Corporation.
kokospb
kokospb
Software reinstallation helped this time! Thank you for your help!
Best regards,
Senior Architect,
RUUKKI Corporation.
Best regards,
Senior Architect,
RUUKKI Corporation.
