Using Text Fields
Using Text Fields
Using Text Fields
I've been able to use the tab designation as a sheet number in a title block and also as the description of a view port.
I've also been able to use the filename text field in different locations in my title blocks too.
There are so many different options for text fields though that it would seem impossible to learn what they all are used for.
Is there someplace I can go that will show me a list with a basic understanding of what each choice might be used for?
At the moment I would really like to know if there is one that will allow me to use the scale of a viewport to autofill the scale in a titleblock?
Thanks once again for looking.
Radar
dbroad
Use the online help.  It is rather extensive.
Use an object field, select the viewport.  The rest should be obvious.
Architect, Registered NC, VA, SC, & GA.
