The biggest hurdle that I have faced so far using AutoCAD has been workflow. I have been stuck for an embarrassingly long time on this subject. The biggest problem is that the tutorials that I have watched on the subject don't even touch on how we would use AutoCAD in the real world. Meaning that the guys creating these tutorials are creating just 3d models and not really explaining how you would draw an actual set of working drawings complete with truss layouts, footings, electrical plans, plumbing plans, etc.
That moves me to the subject of Project Navigator. I thought I was getting things set up properly by getting my sheet sets and layers set up. Then I hear about PN and it totally threw me a curve ball. In the software that I was using, the entire drawing was in one file with several layout tabs. As far as I can tell, you guys are using (correct me if I'm wrong) a floor plan as an xref then creating several other drawings. So the roof plan would be it's own drawing, foundation, etc. One of the things that just makes my head hurt is how would you see where your loads are coming from and going to with everything being separate drawings? In the other software that I use, I toggle my layers so that I can place an expanded footer under a girder truss. That footer then automatically shows up in the viewport.
So my big question is, what is the best and most logical way to deal with these issues? I know there has to be a simple answer. AutoCAD is pretty much the king in the CAD world, so how do you guys who are using the software for creating actual working drawings deal with this? This is the only thing keeping me from moving forward in learning the software at this point. I made this switch in an effort to make myself a more valuable draftsman since this is the program that most Architects and Engineers use.
One last note. The other thing that confuses me is that the way I would develop my own template is to draw an entire set of house plans. I would set up all the settings, styles, symbols, blocks, etc then save that template and all of those things would then be available from that point forward. How do you handle something like this if you have multiple drawings for each project? I appreciate any help. If I can just get over this hump, I think I can move forward pretty well.
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
