User interface confusion
Renee_Ve
Renee_Ve
hello,
I am using default user interface, but I lost it, and I don't know how to go back to default.
Should be very simple, but it is very hard, can't find it. My current workspace has been altered while I don't wont it .
I have lost my menu's by misclicking something but don't know how to get them back.
I am basically working with commands only at the moment ad really could use some help to get a decent UI.
pendean
Community Legend
Community Legend
David_W_Koch
@Renee_Ve
Any chance you activated "Clean Screen?"
CTRL+0 will toggle between normal and clean screens.  Worth a try before resetting the entire interface.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
R_Tweed
You say you lost your "menus"?
1. menubar 1  if you are using menus rather than ribbon.
2. cleanscreenoff ctrl+0 per @David_W_Koch
3. ribbon in case you closed your ribbon.
Renee_Ve
Hey thanks I had closed my ribbon.
However how do I change the look of the ribbon back to default? It looks like this at the moment .
David_W_Koch
You have minimized the ribbon to tiles.
There is a button with an upward-pointing triangle to the right of the ribbon tabs.  Left-click on that to cycle through the options you have picked.  If you are on Cycle through All, you will need to click three times to get back to the full ribbon.  If you are just toggling between full and one of the reduced states, a single click will do.
You can select the downward pointing triangle to the right of the cycle button to get a context menu where you can choose to toggle between full and one reduced state or to cycle through all of the states.
David Koch
Blog | LinkedIn
