- Mute
- Permalink
- Report
This is driving me crazy. The two stairs in the attached file are the exact same stair...except one is set UP and the other is set DOWN. Literally drew one and copied it and changed the vertical orientation and reset the elevation.
Risers at the landing SHOULD be the same. I don't care if they are offset or lined up....just need them the same.
Start of stair and arrow of direction of travel should be opposite, but they should line up.
I need to be able to show the full bottom run for a stair detail sheet so it's not good enough to have a cutline at the default 3'-6" and pretend that the two plans match.
