I have two problems with an AutoCAD file. This file is from an Architect. My AutoCAD is 2022 version. When I dimensioned it, it shows the distance in imperial system. All other previous dimensions are metric. The dimension text size is too small. When I changed the text size to over 100 larger in properties palette, they stays very small and I did not see any changes of the dimension text size. How should I solve these problems? Thank you in advance.
