Unable to install Autocad Architecture 2017
When I launch to install him everything works and when I choose to install AUTOCAD that launches a window of download then it tell me that the download is finished and that the programs did not stink to be installed.
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY Current Directory C:\Autodesk\AutoCAD_Architecture_2017_French_Win_32_64bit_wi_fr-FR
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY CommandLine /PK 185I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/AutoCAD_Architecture_2017_French_Win_32_64b..."
2017/1/5:17:32:42 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI9D2F.tmp
2017/1/5:17:39:23 DJSHA PCGAMERRÉMY === Setup ended ===
2017/1/5:17:32:45 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:32:45 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:32:45 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI9D2F.tmp
2017/1/5:17:32:45 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:32:46 DJSHA PCGAMERRÉMY Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:32:46 DJSHA PCGAMERRÉMY Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:32:47 DJSHA PCGAMERRÉMY Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:39:23 DJSHA PCGAMERRÉMY Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:39:23 DJSHA PCGAMERRÉMY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DJSHA\AppData\Local\Temp\_AI9D2F.tmp\Setup\AcSetup.dll
2017/1/5:17:39:23 DJSHA PCGAMERRÉMY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/5:17:39:24 DJSHA PCGAMERRÉMY PageOpen LaunchDialog
2017/1/5:17:39:34 DJSHA PCGAMERRÉMY PageOpen LicenseDialog
2017/1/5:17:39:34 DJSHA PCGAMERRÉMY PageOpen ProductInfoDialog
2017/1/5:17:39:34 DJSHA PCGAMERRÉMY PageOpen ProductSelectionDialog2
2017/1/5:17:39:38 DJSHA PCGAMERRÉMY PageOpen FullProgressDialog
2017/1/5:17:39:39 DJSHA PCGAMERRÉMY Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:39:39 DJSHA PCGAMERRÉMY Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:39:39 DJSHA PCGAMERRÉMY Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:39:50 DJSHA PCGAMERRÉMY Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:39:50 DJSHA PCGAMERRÉMY Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/1/5:17:39:58 DJSHA PCGAMERRÉMY Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2017/1/5:17:39:58 DJSHA PCGAMERRÉMY PageOpen InstallCompleteDialog
2017/1/5:17:40:54 DJSHA PCGAMERRÉMY === Setup ended ===
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY Current Directory C:\Autodesk\AutoCAD_Architecture_2017_French_Win_32_64bit_wi_fr-FR
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY CommandLine /PK 185I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/AutoCAD_Architecture_2017_French_Win_32_64b..."
2017/1/5:17:47:42 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI58FE.tmp
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY === Setup ended ===
2017/1/5:17:47:44 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:47:44 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:47:44 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI58FE.tmp
2017/1/5:17:47:44 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DJSHA\AppData\Local\Temp\_AI58FE.tmp\Setup\AcSetup.dll
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/5:17:47:45 DJSHA PCGAMERRÉMY PageOpen LaunchDialog
2017/1/5:17:50:07 DJSHA PCGAMERRÉMY PageOpen LicenseDialog
2017/1/5:17:50:07 DJSHA PCGAMERRÉMY PageOpen ProductSelectionDialog2
2017/1/5:17:50:12 DJSHA PCGAMERRÉMY PageOpen FullProgressDialog
2017/1/5:17:50:12 DJSHA PCGAMERRÉMY Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2017" SETUP_PACKAGECODE={28B89EEF-0004-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={4B4A5042-B0BB-4CB0-ACC7-0DB6FAFF4540} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/5:17:50:13 DJSHA PCGAMERRÉMY Install Network License Manager Succeeded
2017/1/5:17:50:14 DJSHA PCGAMERRÉMY Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:50:14 DJSHA PCGAMERRÉMY Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:50:14 DJSHA PCGAMERRÉMY Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/UCRT...
2017/1/5:17:50:24 DJSHA PCGAMERRÉMY Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/UCRT...
2017/1/5:17:50:24 DJSHA PCGAMERRÉMY Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/1/5:17:50:26 DJSHA PCGAMERRÉMY Install Universal C Runtime (KB3118401) Succeeded
2017/1/5:17:50:26 DJSHA PCGAMERRÉMY Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:50:52 DJSHA PCGAMERRÉMY Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:50:52 DJSHA PCGAMERRÉMY Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\DJSHA\AppData\Local\Temp\vcredist_x86_2015.log
2017/1/5:17:50:55 DJSHA PCGAMERRÉMY Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/1/5:17:50:55 DJSHA PCGAMERRÉMY Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:51:21 DJSHA PCGAMERRÉMY Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:51:21 DJSHA PCGAMERRÉMY Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\DJSHA\AppData\Local\Temp\vcredist_x64_2015.log
2017/1/5:17:51:25 DJSHA PCGAMERRÉMY Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/1/5:17:51:25 DJSHA PCGAMERRÉMY Download Play CADM http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/CADM...
2017/1/5:17:51:34 DJSHA PCGAMERRÉMY Download Complete CADM http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/CADM...
2017/1/5:17:51:34 DJSHA PCGAMERRÉMY Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2017" SETUP_PACKAGECODE={28B89EEF-0004-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),;;;;" PACKAGEUPI={4B4A5042-B0BB-4CB0-ACC7-0DB6FAFF4540} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/5:17:51:35 DJSHA PCGAMERRÉMY Install Autodesk CAD Manager Tools Succeeded
2017/1/5:17:51:35 DJSHA PCGAMERRÉMY Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SUCC...
2017/1/5:17:51:36 DJSHA PCGAMERRÉMY Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SUCC...
2017/1/5:17:51:36 DJSHA PCGAMERRÉMY PageOpen InstallCompleteDialog
2017/1/5:17:51:39 DJSHA PCGAMERRÉMY === Setup ended ===
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY Current Directory C:\Autodesk\AutoCAD_Architecture_2017_French_Win_32_64bit_wi_fr-FR
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY CommandLine /PK 185I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/AutoCAD_Architecture_2017_French_Win_32_64b..."
2017/1/5:17:56:12 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI212E.tmp
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY === Setup ended ===
2017/1/5:17:56:14 DJSHA PCGAMERRÉMY === Setup started on PCGAMERRÉMY by DJSHA ===
2017/1/5:17:56:14 DJSHA PCGAMERRÉMY Path_Length: 162
2017/1/5:17:56:14 DJSHA PCGAMERRÉMY Current Directory C:\Users\DJSHA\AppData\Local\Temp\_AI212E.tmp
2017/1/5:17:56:14 DJSHA PCGAMERRÉMY Launch
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/SETU...
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\DJSHA\AppData\Local\Temp\_AI212E.tmp\Setup\AcSetup.dll
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/5:17:56:15 DJSHA PCGAMERRÉMY PageOpen LaunchDialog
2017/1/5:17:56:24 DJSHA PCGAMERRÉMY PageOpen LicenseDialog
2017/1/5:17:56:24 DJSHA PCGAMERRÉMY PageOpen ProductInfoDialog
2017/1/5:17:56:24 DJSHA PCGAMERRÉMY PageOpen ProductSelectionDialog2
2017/1/5:17:57:35 DJSHA PCGAMERRÉMY PageOpen FullProgressDialog
2017/1/5:17:57:38 DJSHA PCGAMERRÉMY Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:57:38 DJSHA PCGAMERRÉMY Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/STAR...
2017/1/5:17:57:39 DJSHA PCGAMERRÉMY Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{3CA9E5EA-DB60-4499-AA1F-70FAD4DF5088}/VCRE...
2017/1/5:17:57:39 DJSHA PCGAMERRÉMY Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/1/5:17:57:46 DJSHA PCGAMERRÉMY Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
dzanta
i would do the following:
1.  go to upandready.typepad.com and use Ask Virtual Agent to download the installation files (avoids the download/installation manager)
2.  uninstall your ms redistributable c++ files (your workstation has newer c++ files than those on the installation files)
3.  install ACA
4.  run windows update to get current c++ files
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
