Unable to batch plot
Message 1 of 10
Been having problems with batch plot. I'm getting an SDI error, telling me to set the SDI to 0. However, program is not allowing me to do that. Re installed the program, both times problem returned after 1 week. Typically I restart the program or my computer then I can batch plot. Now neither works. Please help. Thanks.
Replies (9)
Message 2 of 10
leothebuilder
And how are you batch plotting?
Publish command?
.dst file?
Multiple layouts with right click/publish?
Is background publishing set to on or off?
Message 3 of 10
Thanks for responding.
batchplot command
no .dst file, just specific sheets
multiple layouts within one file
background publishing is off.
Message 4 of 10
pendean
Community Legend
Community Legend
Can you post a screenshot of the exact error, plus a screenshot of your PUBLISH and ABOUT commands pop-ups please.
Message 5 of 10
IMG_5202.jpgIMG_5203.jpgUntitled.jpgHere you are. Apologies for the rotated photo. I rotated the photo and saved it but for some reason can't upload it as I see it on my screen. Anyway, thanks again for any help.
Message 6 of 10
pendean
Community Legend
Community Legend
Thanks for the screenshots: please explain what you mean by "...program is not allowing me to do that..." when you try to set SDI to 0 (zero)?
Message 7 of 10
leothebuilder
SDI is a system variable, 0 (zero) is off and 1 in on.
On the command line enter SDI and set the value to 0 (zero)
Message 8 of 10
I've tried that many times. It's stuck in 3.
Message 9 of 10
David_W_Koch
That is odd, as SDI only accepts values of 0 or 1.  What happens if you type this at the command line, and then press the ENTER key.
(setvar "SDI" 0)
Be sure to include both parentheses; you will be using AutoLISP to set the SDI system variable value.
Have you tried a repair or reinstallation of AutoCAD Architecture?  Please back up all customizations before doing so.
The value is stored in the Windows Registry, for each AutoCAD Profile you have defined.  If you are not comfortable with editing the registry, then I would advise against trying to fix the value this way.  If you are comfortable with editing the registry, then I advise you to make a backup of the registry before you make any changes, just to be safe.  The SDIMode registry key can be found under
Computer\HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R23.0\ACAD-2004:409\Profiles\[YOURPROFILENAMEHERE]\Drawing Window
where you would substitute the name of your AutoCAD Profile for [YOURPROFILENAMEHERE].  If you select Drawing Window in the left pane, you can scroll down in the right pane and double-click on SDIMode.  In the Edit DWORD (32-bit) Value, enter 0 in the Value data edit box and select OK.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 10 of 10
pendean
Community Legend
Community Legend
SDI Settings
This list shows valid settings for SDI and explains what each setting does.
0 Multiple drawing interface enabled
1 Multiple drawing interface disabled
2 Multiple drawing interface disabled by an application that does not support multiple drawings
3 Multiple drawing interface disabled by user and by an application that does not support multiple drawings <<<<<< YOUR ISSUE: AN ADD-ON+ RESTRICTED WINDOWS LOG-IN
