UCS appears next to an object every time I select it. How do I remove it?
Message 1 of 10
I was trying to get the navcube back onto my screen and must have hit a button so that the ucs appears every time I select an object.  I am hoping for instructions on how to remove it?  Thank you.
Replies (9)
Message 2 of 10
MarySeufert
From your description I think it is actually the 3D move Gizmo that is in the way. Set DEFAULTGIZMO to 3.
From help: DEFAULTGIZMO
Type:Integer
Saved in:Not-save
Initial value:0
Sets the 3D Move, 3D Rotate, or 3D Scale gizmo as the default during subobject selection.
0The 3D Move gizmo is displayed by default when an object is selected in a 3D visual style.
1The 3D Rotate gizmo is displayed by default when an object is selected in a 3D visual style.
2The 3D Scale gizmo is displayed by default when an object is selected in a 3D visual style.
3No gizmo is displayed by default when an object is selected in a 3D visual style.
EXPERT ELITE MEMBER
Message 3 of 10
Thank you so much!  That's exactly what it was.
Message 4 of 10
npettyRW9D4
Observer
Observer
THANK YOU LOL.  It's been bugging me for a few days and then I couldn't remember if it was always there or not... But I knew it couldn't be so, I'd remember it bothering me this much.
Message 5 of 10
I went to the view ribbon in AutoCAD 2014 and in the visual styles section selected "2D wireframe" in the drop-down menu and it worked.
Message 6 of 10
hi i have same problem for him but i don't understand how to solve it
can you tell me the steeps again and if u can with photos please
Type:Integer
Saved in:Not-save
Initial value:0
hi acutaly i have same problem but i dont understand how can i solve it
please can you tell me again step by step and if you can with photos it will be nice from you
Message 7 of 10
MarySeufert
Enter DEFAULTGIZMO at the command line.  Enter the numerical value you want.
This will change the value of the system variable that controls the appearance of the Gizmo.
EXPERT ELITE MEMBER
Message 8 of 10
i try what you tell my not work  please help me what i have to do exactly
to remove this ucs after each selection appear
Message 9 of 10
no gizmo же
Message 10 of 10
Mohamedhamdyacc0
choose view from ribbon and then go to visual styles (change visual style to 2D wireframe)
