AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Texture Editor not opening or not visible
3 REPLIES 3
wwhite35
323 Views, 3 Replies
Either the texture editor is not opening or is not visible when clicking on an image in the Materials editor. Have tried everything I can think of to locate behind other items or on other screens.  Moved, reduced size, changed screen resolution, disabled and enabled monitors. Any suggestions? Worked fine a week ago.
3 REPLIES 3
pendean
in reply to: wwhite35
Did you try moving it in the CUI command yet?
wwhite35
in reply to: pendean
Not sure how to do this. Typed CUI, opened the box, found image editor command, then what?
[cid:image001.png@01D70466.5BA934B0]
pendean
Explore these methods first that are more than what you've tried so far https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog...
CUI method (workspace editing) may not apply here.
