Table formula not rounding up
tevansHMH
tevansHMH
I have added formulas to table cells that I want to always round up if more than a whole number. I have tried round() and trunc() and neither will round up. My formula looks like this
=trunc(((D3/150)*144)/2)/56 this returns 22.285714 not 23
=trunc(((D3/150)*144)/2)/144 this returns 8.666667 not 9
D3 enters a value in Cell D3
Data Type is set to Decimal Number and Formatting is set to (none)
All I can find in my research is to use either round() OR trunc() and neither work in my case.
Thank you in advance for your help.
dbroad
Match your parentheses  The formulas must be in the form: =function (argument)
Example: =round(D3/150*144/2/56)
If this is about venting or occupant load though, you may always need to round up.
Architect, Registered NC, VA, SC, & GA.
tevansHMH
yes, this is for attic ventilation so must always round up.
dbroad
Note: The round function doesn't always round up.
tevansHMH
Is there a function that will force it to round up?
dbroad
Excel has a roundup function. With AutoCAD, round(#+0.5) will do.
