I was wondering if there is a certain standard as far as coloring layers/blocks goes for buildings/layouts/equipment. I cannot seem to find a basic standard for what each color is commonly used to identify. AIA and the National CAD Standards does not seem to specify. Other than white used for exterior walls, what are some common colors used for specific block features within a building design?
Thanks.
If you will be using ACA, choose one of the built-in layering standards which are built on AIA and National CAD standards or use the British Standard. Anything else will probably be a waste of time unless you have problem discriminating between certain colors. The main choice you should be making is whether you want style based or color based plotting.
