Setting up Project Standards issue
tevansERD
tevansERD
I am trying to configure project standards in my template. Set everything up and select ok then reopen nothing is saved. Any ideas why this is happening?
pendean
Community Legend
Community Legend
Can you walk us through your workflow in longer list of steps, commands and options?
tevansERD
I open the Configure AEC Project standards  dialog box
I select the Standards drawings to  use and set the objects for each to check on the Standards Styles tab
I selected semi-automatic on the Synchronization tab
I selected my standards drawing on the AutoCAD Standards tab
Selected OK
Added notes in the version dialog box
selected ok the dialog box closes
If i reopen the configure dialog box all settings are lost
pendean
Community Legend
Community Legend
Did you go through the Prerequisites for Working With Project Standards by chance to see what steps you might have missed?
https://knowledge.autodesk.com/support/autocad-architecture/getting-started/caas/CloudHelp/cloudhelp...
