Select Similar missing from Right-Click Menu and CUI
Message 1 of 12
For whatever reason the "select similar" command has disappeared from both my right click menu and my cui list when I'm in my personal profile on Architecture... Can't seem to get it back in my personal profile although can access it if I go back to the Autodesk Standard profile.
Any help is appreciated.
Thanks!
Replies (11)
Message 2 of 12
If you're comfortable using RegEdit, this may be easy to diagnose and fix.
Navigate to (note that the exact numbers following this may vary)
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8004:409\Profiles\{PersonalProfileName}
and look for the Value "IsPureAcadProfile". If this exists and is set to 1,
change it to zero. You didn't mention it, but this would also cause many
other changes in the appearance and behavior of AutoCAD Architecture. For
example, WALL would be an unknown command.
Hope this helps,
Bill Glennie
AutoCAD Architecture Team
Message 3 of 12
I face the same problem even after changes made as per your instruction. and i face one more problem that, when i select a object and delete it, it is not deleting, it is asking for the object again. so please istruct me for this problem, i am using autocad 2013 and in windows Xp.
Message 4 of 12
David_W_Koch
For your delete issue:  set PICKFIRST to 1.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 5 of 12
Excactly correct....... thankyou verymuch.
Message 6 of 12
Dear mr. David Koch,
Thanks for your suggestion, i actually forgot that command and was feeling very down to ask my office met but you solved my problem. Thank you thank you very much, from now i will keep in note. Once again tq tq very much
Message 7 of 12
THANK YOU VERY MUCH
PICKFIRST -1
Message 8 of 12
User_2011
Restart AutoCAD.
Message 9 of 12
What is regedit? How can I do it?
Message 10 of 12
pendean
Community Legend
Community Legend
Message 11 of 12
SDonovanBEH6R
The hot reg link doesn't work anymore. I can't get SELECTSIMILAR to show up when I right click. PICKFIRST is set to 1 and SHORTCUTMENU is set to 11 and it's still not showing up.
Message 12 of 12
pendean
Community Legend
Community Legend
@SDonovanBEH6R wrote:
...I can't get SELECTSIMILAR to show up when I right click...
neither of those variables has much to do with CUI command tools.
What year version of ACA are you running please? And which ACA profile are you running? And which workspace?
I believe you can add it manually using CUI command, but its not missing here so I've not tried it
