Section Dialog window
07:02 AM
Good evening,
I'm David, I work as engineer in Trento, Italy.
I write you cause I have some problems with Autocad Architecture 2017.
With Autocad Architecture 2015, when I generated a 2D section (Vertical or Horizontal) from a 3D object I was used to get automatically the dialog window. With the 2017 I don't get it anymore, I have to open it manually.
There some variable to change or some setting to flag to obtain the dialog window of vertical and horizontal section automatically?
Where can I set the properties of this command?
Thank you for your attention,
Good evening,
David
