Section Dialog window
Good evening,
I'm David, I work as engineer in Trento, Italy.
I  write you cause I have some problems with Autocad Architecture 2017.
With Autocad Architecture 2015, when I generated a 2D section (Vertical or Horizontal) from a 3D object I was used to get automatically the dialog window. With the 2017 I don't get it anymore, I have to open it manually.
There some variable  to change or some setting to flag to obtain the dialog window of vertical and horizontal section automatically?
Where can I set the properties of this command?
Thank you for your attention,
Good evening,
David
leothebuilder
Welcome to this forum.
Instead of the dialog box, do you still have prompts at the command line when invoking the section tool?
Check some of your variables settings described here:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
