screen data entry setting
kgm2535
kgm2535
how do you enter object dimension information on the screen rather than at the command line
attached is what I want set for drawing a rectangle rather than at the command line
enter width then tab over enter height.  this would be seen on the display screen like the line command
rkmcswain
Look into the DYNMODE system variable, and/or the DSETTINGS command.
R.K. McSwain     | CADpanacea | on twitter
kgm2535
Hi thanks
its works from the pointer using the (Dsettings)
the rectangle jumps back to the  x,y origin.  how do you set the start point to be independent of the origin
ie a 2"x10" joist 10 ft long . I want the joist to start where I click the start point . it seems to jump back to x,y
pendean
Community Legend
Community Legend
@x,y is the typing method you would use from a selected starting/origin point.
