Scaling a converted pdf file to drawing to coincide with the given coordinates
Hello everybody!
My problem is like this. I received a pdf file drawing site layout and converted it using any pdf to drawing converter software. And after converting it I had noticed that everything were exploded. Now, I need to input the given coordinates (actual survey) of the structures to be reflected in the autocad drawing to show the exact location of it. Anyone knows how to work with it and come up a skilled drawing? I know real surveyor knows this and other talented users of autocad. May I ask your help?
leothebuilder
If you need an accurate drawing maybe it's best to contact the author of the original drawing and ask for a copy of the cad file.
That would be my approach. If that does not work, you have a lot of editing ahead to make the exploded PDF accurate.
