11:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i would like to rotate an object to match the angle of another. I can measure the angle but there are many decimal points and I want it to be exact.
One method i have employed is to change the ucs - z setting to align with the object to be rotated then click it and select a point that intersects the other object (this case a line) and then the 2nd snap is somewhere along the line.
this works although sometimes i have to rotate a second time 90 deg. or 180 to get proper orientation.
Is there method, or hidden snap?
ACA2011 Win 7
