retrieve ctb after resetting to defaut
I reset the AutoCAD and the custom ctb I created is missing. How to retieve it?
Thanks in advance
David_W_Koch
Any chance you can use the Windows Restore Previous Versions feature on the folder in which the missing plot style file was kept?  (I assume that if you had backed up the file, you would not be posting the question.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pendean
Community Legend
Community Legend
Did you make a copy and save it somewhere safe?
Or retreive it from your PC backups?
OR..
Before the RESET, AutoCAD told you it was going to backup your profile and save it somewhere in a ZIP file, did it and did you look in there?
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
I'm just checking in to see if you need more help with this. It looks like @David_W_Koch and @pendean provided some recommendations to help you recover your lost CTB file. Did either of them point you in the right direction?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
