PDF printing issue with no texture style
Hi everybody,
I've an issue about printing PDF.. I created a new visual style with those parameters (image6 sorry it's in french). Those parameters give me the visual in a presentation sheet that you can see on the image2. But when I try to print it in PDF file, I obtain the visual you can see on image4.
I stuck on this problem since a while and I don't find who I can solve it.
Thanks for your help guys.
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
If you select the viewport and check the Properties palette, what is the Shade Plot setting?
If you change it to As Displayed (or a different setting than it's set to currently), does it plot correctly?
If this doesn't work, please post your DWG file here and we'll be happy to take a look directly to figure out what's going on.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Hi @Victoria.Studley,
Thx for your quick reply !
Indead, I already tried this setting and it's worse 🙂
It print all textures even those which are in background.
Anyway, I give you the dwg, I hope it won't take lot of your time 🙂
Regards
-FDC-
I am afraid you will have to use the Hidden visual style and change it instead of making a copy.
Whenever you copy the hidden style you lose the materials.
When you type Hide at the command bar it goes back to the hidden style.
At shademode he does the same.
A bug ?
Maybe there is a parameter or variable to display the material but I can't find it.
I found the solution, There is a little button which switch the haches view at the bottom right of the interface.
But thx anyway for your support 🙂
-FDC-
Glad I could help and great that you did find the solution!
-FDC-
Strange, this little button doesn't work here with your visual style "perso".
Only on the hidden style.
You are sure it is working on your PC and with your "pesro" visual style?
