Rendering materials do not display in AutoCAD Architecture 2018
I am in the process of trying to render a design; however, my applied materials are not being displayed or rendering out.  I have already adjusted the styles manager.
Any help or suggestions as to how to fix this is greatly appreciated!
@Anonymous for clarity VStudley edited the original subject: Rendering in AutoCad Architecture 2018
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
Could you share a screenshot and sample DWG file where the issue is happening?
You may also want to check your Graphics Configuration settings, to ensure Advanced Material Effects is enabled:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
