We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Railing not attaching to inner stair stringer in AutoCAD Architecture
Capture.JPGI AM TRYING TO ATTACH A RAILING ON THE INSIDE STRINGER CURVE BUT IT WONT ATTACH TO IT. PLEASE HELP
@Anonymous for clarity Kevin.Palmer edited the original subject: AutoCAD Architecture 2018 Railing Problem
Kevin.Palmer
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
What method are you using to try to attach it? It should automatically attach when you select the railing tool and click the edge that you want to place it on. Would you be able to Record a Screencast and upload it here?
I also wanted to point you to this article about Creating an Attached Railing. There is some great info here that might also help.
Hi thank you for the reply i actually just figured it out......for some
reason on the inside stringer it was very stubborn so i had to click on the
heel edge by zooming in and it did add it this time.
